Hi all,
I currently have vdj home edition 5, is it worth upgrading to broadcaster?
Thanks
Thanks
geposted Sun 18 Mar 12 @ 9:48 am
It depends on what you need or better want! ;-)
https://virtualdj.com/products/comparison.html
geposted Sun 18 Mar 12 @ 1:06 pm
Yer, I have seen the comparison, but I know that home edition is very similar to broadcaster.
What I am getting at is - is it worth the $39 to get broadcaster if I already have HE5? Am I getting any more funcionality for that cash?
geposted Sun 18 Mar 12 @ 1:09 pm
I should clarify, I bought HE5 four or so years ago back when it included the ability to broadcast
I am unsure as to wether the new broadcaster is just a re-badged home edition v.5 or wether it is an improvement over it.....
geposted Sun 18 Mar 12 @ 2:46 pm
No answers on this?
geposted Tue 20 Mar 12 @ 8:15 am
It is hard to advice, because i can't look into you ;-)
When i now tell you to buy the Broadcaster and you come back and tell me, there is no difference?
The Broadcaster is newer then the Home5 and hold some more things.
But also you will miss something. For example the possibility to split soundcard channels.
But if you use only a propper soundcard, you won't miss it!
Have a look to the sheet above and check if anything is there you wanna need.
Sorry ;-)
Sorry ;-)
geposted Tue 20 Mar 12 @ 2:33 pm
