Topic: prime loops
I was wondering if it is possible to use "Prime Loops" with virtual dj pro 7 ?
geposted Sat 07 Jul 12 @ 5:41 pm
Greetings,
Don't know if you've been following my posts about WAVE and AIFF loop/sample issues. I bought a bunch of loops & samples from PLP and I am having problems.
PLP looks to be the same type of loop and sample company as PRIME LOOPS. Here is what I learned:
If you order loops & samples from this company specify you need 16 bit not 24 bit. The 24 bit files just "hiss" like white noise when played with VDJ PRO 7. The identical 16 bit files work fine.
And... VDJ PRO 7 cannot play AIFF files in the sampler. You will need WAV files for that.
And... I've been having problems with WAV files "chirping" at the end of play in a deck. The sampler plays and loops them fine. The problem seems to be these loops and samples are in Windows PCM format. I get rid of the "chirping" by re-saving them as ACM Waveform.
I'm looking for a batch converter now to do these 1500 or so files I purchased. One by one would be a pain-in-the-rear.
Regards,
Jimmy of the Jam
