Forum: Old versions
Topic: DDJ WeGo not working with VDJ Pro
I already own Virtual DJ Pro and just purchased the DDJ WeGO. However I want to be able to take full advantage of my Virtual DJ Pro. However once I install the VDJ LE I can not find the mappings on my pc, neither does VDJ Pro respond to the MIDI Controller. Is there any easier solution than to map the controller for Pro. And if so, how can I embed the light effects of the controller into this mapping? (I.E. make the play button flash once a new track is loaded on the MIDI Controller)
geposted Fri 05 Oct 12 @ 11:29 am
What version of VDJ Pro are you using (and why haven't you registered it)?
The WeGo is definitely supported in the latest version. I just checked.
geposted Fri 05 Oct 12 @ 11:59 am
Since you own PRO Full you should register your serial number on your profile HERE and then download the latest version (7.1) from HERE.
This way you'll be able to work with DDJ-WeGo and your copy of PRO
geposted Mon 08 Oct 12 @ 7:10 am
Same it happend to me Pro v 7.04 does not respond to wego like LE does?
How can we fix it.
geposted Thu 21 Mar 13 @ 6:48 pm
nindozHome userMember since 2012
one thing you could do (which worked for me) was to go to the midi mapper but it can get a bit complicated
geposted Tue 16 Apr 13 @ 1:59 pm
Deco_d1PRO InfinityMember since 2014
I have the same problem VDJ won't recognized wego
geposted Thu 08 May 14 @ 11:41 am
Are you saying that the LE version supplied with the WeGO doesn't recognise it?
geposted Thu 08 May 14 @ 11:47 am
