I've Been Using Serato Itch, But Something Has Been making My Set Up Crash Lately. (Hardware Disconnected) So I Plan On Using Virtual DJ. Since It Seems To Be Not Crashing Like Serato Itch. But My Question Is After I Open VDJ & Click (Config) Then (Mappers) Everything Is Check Off = use keyboard shortcuts,use hid devices,use midi devices,ect,ect. Some Websites Say (HID Mode) Is Better & More Stable Than (Midi Mode) ? So Should I Uncheck One Or The Other ? Or It Wont Matter. Because The NS7 & VDJ Will Work In Either Mode ?
geposted Thu 27 Dec 12 @ 3:57 pm
I just fire it up, go into Config:
hit "Apply" NS7 with ultra latency checked
"Enable" video
Options for jogs are set by registry ( 1024 )
Sound card settings for latency are set to "Auto"
I dont know anything about the HID vs MIDI, they've both always been checked.
I do feel & see a difference between W7 & W8, 8 is still not as tight for me as 7 but works well.
"Enable" video
geposted Thu 27 Dec 12 @ 4:54 pm
The NS7 is MIDI. However, under normal circumstances, you should not need to disable detection of HID devices, even if you aren't using any.
For best results, please ensure that your computer has been optimised for DJ use: http://www.virtualdj.com/wiki/Performance%20Issues.html
geposted Fri 28 Dec 12 @ 7:31 am
Virtual dj is not reading my ns7 what options do i have
geposted Thu 11 Feb 16 @ 6:28 pm
Change the USB cable or try a different port?
Has it worked previously, operating system, VDJ version etc?
We can't help with that limited amount of information.
geposted Thu 11 Feb 16 @ 6:38 pm
