Forum: Old versions
Topic: Help Mapping a button to turn crossfader on and off
sbproxyPRO InfinityMember since 2011
Hey new mapper here in need of some help! I like using the crossfader on my MIDI controller, but sometimes I bump it when i dont want to, so i want to be able t press a key on my keyboard to turn it on and off. How do I map this? I tried 'activate on" "activate off" and it didnt work.
Thanks in advance.
geposted Thu 24 Jan 13 @ 2:59 am
button to tun on/off
toggle 'cf_off'
crossfader
var 'cf_off' ? nothing : crossfader
if you want to take advantage of the soft takeover map this to the crossfader instead
var 'cf_off' ? nothing : crossfader_slider
geposted Thu 24 Jan 13 @ 3:07 am
technzPRO InfinityMember since 2011
on the button.
"var_equal '$faderon' 1 ? set '$faderon' 0 : '$faderon' 1"
on the crossfader
"var_equal '$faderon' 1 ? crossfader_slider : nothing"
if you want a led to display whether crossfader is enabled
"var_equal '$faderon' 1 ? on : off"
edit: my method is the same method as synthet1c posted, just far more long winded and might be easier to understand for some people
geposted Thu 24 Jan 13 @ 3:08 am
IT WORKS LIKE A CHARM
Thank you both, you guys helped me out unbelievably quickly. I'll be making this mod to my jogwheel too.
Much appreciated
geposted Thu 24 Jan 13 @ 3:39 am
You can always use the internal crossfader adjustment too:
"crossfader_curve 'disabled' ? crossfader_curve 'smooth' : crossfader_curve 'disabled'"
And for the LED:
"crossfader_curve 'disabled' ? off : on"
PS: The "crossfder_curve" command controls the internal crossfader option of the software. In other words it will disable the crossfader on BOTH the controller, AND the skin/GUI!!! It's the same as opening config and turning crossfader option to "disabled"
geposted Thu 24 Jan 13 @ 3:51 am
Break69Home userMember since 2017
Thanks so much the crossfader doesn't work at all.
geposted Thu 13 Apr 17 @ 12:51 am
On the screen with your mouse?
Or on a controller? Because you shouldn't be able to use VDJ with a controller for more than a 10 min test period when you use the free home edition
geposted Thu 13 Apr 17 @ 7:16 am
