Hello as you know the mixtrack pro 2 has a passthrough instead i plug my new mic into the pc and do input microphone output headphones then the bottom thing as the 4.1 card
it works but the problem is i hear myself through my headphones howw can i stop this as it disrupts me from talking.
geposted Wed 03 Apr 13 @ 9:07 am
bump
geposted Wed 03 Apr 13 @ 5:57 pm
You did not really post many informations bout your problem.
Which Windows version exactely ?
Which version of Virtual DJ are you using (exactely) ?
Greets, Heiko
Greets, Heiko
geposted Thu 04 Apr 13 @ 2:11 am
I can mix but I cant record my mic sound..help needed...
geposted Thu 02 Oct 14 @ 10:36 am
As stated in the first post, the mic input on the MTP(2) is fed to the output of the unit.
The audio signal goes from VDJ to the MTP. The mic is plugged into the MTP.
If you use VDJ to record, you are recording the signal before it's reached the MTP (where the mic signal is added).
Therefore if you wish to record the mic, you will need to record from the MTP output - not from within VDJ before the signal reaches the MTP.
geposted Thu 02 Oct 14 @ 10:45 am
groovin knows his stuff!
geposted Thu 02 Oct 14 @ 4:33 pm
