When mixing with VirtualDJ....
Obviously you can adjust pitch (tempo) on either deck independently, but is there any way to adjust the pitch (tempo) on two tracks that are playing together beatmatched or synced (SIMULTANEOUSLY)?
I swear I've heard DJ's anchor/sync/beatmatch two tracks together and then bring the whole shebang down a few bpm while the tracks are playing together....
Is this possible?
Thanks!!
geposted Tue 25 Jun 13 @ 3:40 pm
Yes, this is quite possible.
On the standard skin, there is a little padlock symbol by the pitch control - this is the pitch lock. Click it so its highlighted, and both sync'd tracks will adjust at the same time.
Ta
Mike
Ta
Mike
geposted Tue 25 Jun 13 @ 3:51 pm
Ta
Mike
Ta
Mike
AHH yes! Thank you!
(I feel dumb now.... )
geposted Tue 25 Jun 13 @ 3:54 pm
I'm curious.. Why don't I have a padlock next to tempo on VDJ8
Been through the setting and config and can find nothing.
I did used to have it on VDJ7
Any help is appreciated.
geposted Thu 09 Feb 17 @ 4:15 pm
Script a button, pitch_lock
geposted Fri 10 Feb 17 @ 6:48 am
