Forum: Old versions
For older version, like VirtualDJ 7.
NOTE: VirtualDJ 7 is not maintained anymore.
Topic: Installation Error
Hello,
I am using a samsung series 3 laptop with windows 8.1
I've tried downloading VirtualDj many times from different websites but none has worked. I keep on getting an Installation Error and it says "Installation Package is corrupted".. Please help me if you can
Thanks.
geposted Thu 19 Dec 13 @ 8:43 am
RobRoyPRO InfinitySenior staffMember since 2012
install all "versions" of vdj from your pc system. then try to load the home free version by following this link:
http://www.virtualdj.com/download/free.html
the Pro Full Version ( with Midi Controller Support) is only avaliable here on this site.
geposted Thu 19 Dec 13 @ 2:12 pm
I've uninstalled everything and re-installed it numerous times. still nothing
geposted Thu 19 Dec 13 @ 8:58 pm
Can someone please help me! I've been trying to solve this for weeks now! PLEASE!
geposted Tue 31 Dec 13 @ 5:25 pm
Did you use the link provided above?
geposted Wed 01 Jan 14 @ 2:38 am
Yes I have.
geposted Sat 04 Jan 14 @ 12:34 pm
You have downloaded from several sites, and may have gotten a bug, please contact support
geposted Sat 04 Jan 14 @ 2:53 pm
Mine says something about needing to install on an administrator account or something like that, ive done that and tried to open it and it wouldnt open, it launches if i check off the "Launch VDJ" option after installing it, I need help! :(
geposted Sun 12 Jan 14 @ 1:18 am
