Forum: Old versions
Topic: Assigning Keys (kill Low)
Hi all!
I want to assign some keys on the keyboard to open low to 50% and kill low to 0%.
When I do this like I think it should be done, nothing happens when I press on the assigned button.
In the picture I have my settings for the button Q, to kill low to 0%.
However, when I/m mixing and press the Q button, nothing happens at all.
Al the presets like P (Play) and so on work correctly.
I think I'm missing something...
Can someone tell me what I'm doing wrong por favor?
geposted Mon 23 Dec 13 @ 6:30 am
deck 1 eq_low -100
geposted Mon 23 Dec 13 @ 10:19 am
that one works, I tried yours and it worked too.
geposted Mon 23 Dec 13 @ 10:21 am
deck 1 eq_low -100 (set the bass equalizer) Works now!
deck 2 eq_low -100 (set the bass equalizer) Works now!
When I make it deck 1 eq_low -75 (set the bass equalizer) it doesn't work.
When I make it deck 2 eq_low 50 (set the bass equalizer) it doesn't work.
(Don't mind the deck 1 or 2 setting)
Is the setting "set the bass equalizer" not the right one?
geposted Mon 23 Dec 13 @ 12:39 pm
deck 1 eq_low -50%
deck 2 eq_low -50%
The % is missing
Also
deck 1 eq_kill_low
deck 2 eq_kill_low
is better at killing bass
as pressing it a second time brings the bass back (also works for mid and high)
geposted Mon 23 Dec 13 @ 4:51 pm
Oh I didn't spot you wanted it to effectively reset the bass, just take off the + or -
So
deck 1 eq_low 50%
or you can use
deck 1 eq_low 0.5
Since it's Christmas, copy and paste this into your xml file
<map value="YOUR KEY 1" action="deck 1 eq_kill_low ? deck 1 eq_kill_low &amp; deck 1 eq_low 50% : deck 1 eq_kill_low &amp; deck 1 eq_low 0%" />
<map value="YOUR KEY 2" action="deck 1 eq_kill_low ? deck 1 eq_kill_low &amp; deck 1 eq_low +3.3% : deck 1 eq_low +3.3%" />
The first one checks if the bass has been killed already (off) ? if it has it turns the bass back on & it sets the dial back to the centre : if it hasn't (already been killed) it kills the bass & sets the bass dial to as low as it gets.
The second one checks if the bass has been killed already (off) ? if it has it turns the bass back on and turns the dial up 3.3% : if it hasn't (already been killed) it just turns the dial up 3.3%
So "YOUR KEY 1" Kills the bass, but pressing it quickly twice resets the bass
and "YOUR KEY2" just turns up the bass.
geposted Mon 23 Dec 13 @ 8:02 pm
Thank you very much!!! Works perfect!!
Merry Christmas!!
geposted Tue 24 Dec 13 @ 2:59 am
vidanesPRO InfinityMember since 2006
I am assigning the following to the custom buttons in the latest Mac version with the following results:
eq_kill_low - not wokring
eq_kill_mid - working
eq_kill_high - not working fully, it seems to have some effect
Any ideas on what I may be missing?
geposted Wed 30 Aug 17 @ 9:33 pm
They do work - I've just tested all three
You shouldn't be in doubt when you test it, because they light up the label in red, as seen below:
A guess: Do you maybe have a space or a new-line character in the end of your script?
That often happens when doing copy-paste, and it messes things up
geposted Thu 31 Aug 17 @ 9:12 am
You do need to be using the right EQ mode in order for kills to work.
See this page of the manual, under 2. EQ
geposted Thu 31 Aug 17 @ 5:46 pm
Oh yes, this may be it.
I thought he meant the kills weren't triggered
geposted Thu 31 Aug 17 @ 7:58 pm
