I have no control of the eq knobs on ddi ergo, when i turn the knob for more bass it shows on the vdj but doesn't respond on the output signal. confused
geposted Sun 11 May 14 @ 11:35 pm
Thats due to the Limiter. It is enabled by default to prevent distortion and clipping and cant be turned off.
geposted Sun 11 May 14 @ 11:45 pm
ok so when I'm mixing two songs and want to decrease the bass in the channel that I'm exiting , and add bass to the channel thats entering. how do i do that? are you saying i can't reduce/increase low ,mid, highs at all? confused
geposted Sun 11 May 14 @ 11:53 pm
If your volume is already at maximum you cannot add more. Turning up the bass should still make it sound lower with the high frequencies getting muted.
If you want more control, reduce the gain on the songs, and increase the volume on your amplifier.
geposted Mon 12 May 14 @ 12:54 am
geposted Mon 12 May 14 @ 6:37 am
EQ changes does NOT apply on your headphones. Only on master output.
So if you want to hear EQ changes on headphones please change the option equalizerinheadphones
geposted Mon 12 May 14 @ 6:54 am
thank you
geposted Mon 12 May 14 @ 8:00 am
