Topic: Controller issues
greggenPRO InfinityMember since 2011
I am using a Pioneer Ddj -Ergo controller.
Everything works fine except the equaliser buttons. The gain and filter is ok, but when I use the high - mid - low buttons, I can't hear any difference in the sound.
When I turn them, I can actually see them turning on the screen, but the sound stays the same.
Worked fine on previous Vdj
geposted Mon 12 May 14 @ 2:12 am
Have you tried on master ? Or only in your headphones ?
Because by default you won't hear the EQ change on headphones. You need to change setting "equalizerinheadphones" to yes
geposted Mon 12 May 14 @ 2:50 am
I only use the controller at home, in the weekends I play timecoded, so i only tried headphones.
It works now!
Thx!
geposted Mon 12 May 14 @ 3:22 am
