Topic: Loading tracks
Hi
When loading tracks into Virtual DJ 8 it takes a while for them to load, they are in flac and wav formats. Is there a setting to help with loading tracks issues. Thank you
geposted Mon 12 May 14 @ 5:20 am
delete please
geposted Mon 12 May 14 @ 5:56 am
Jesus sorry for the mistake this should have been posted in my other thread. I still need help for the first message
geposted Mon 12 May 14 @ 6:09 am
Are these tracks that have already been scanned, or not?
geposted Mon 12 May 14 @ 6:33 am
They were scanned in Virtual DJ 7, but not in 8. Do I have to rescan them, I have thousands of songs and its time consuming. Plus i have all my keys bpm etc in virtual DJ 8. I mean if its something that has to be done I will do it.
geposted Mon 12 May 14 @ 6:57 am
You don't have to scan them again, but it might take a little longer to open each file the first time you load them in v8 then.
geposted Mon 12 May 14 @ 6:59 am
i cant drag and drop tracks. have to use "load on"
geposted Mon 12 May 14 @ 7:32 am
drag and drop works with mouse, but not touchscreen-dell venue 8 pro
geposted Mon 12 May 14 @ 7:40 am
I think with touchscreen. Use two fingers to drag and drop?
geposted Mon 12 May 14 @ 7:41 am
For touch screen, there's 2 options for dragging
-multiTouchTwoFingerScroll option that you can set to yes. Then you can scroll with 2 fingers, and drag with 1 finger.
-Put the browser in grid mode (browser options button on the left, show->grid). Now you can drag the cover, and scroll in between the cover
geposted Mon 12 May 14 @ 7:56 am
