Forum: German Forum
Topic: Übersicht der aktuellen bzw. laufenden Builds und Fixes der Version 8 - Page: 4
jakovskiPRO InfinityStaffMember since 2006
28.11.2014
Build 2069
-Fix regression on mac causing crash when thread exits before startThread finished
-get_bpm shows local bpm
-Fix crash on windows with some midi devices sending sysex messages to unprepared buffer
geposted Sat 29 Nov 14 @ 9:14 am
30.11.2014
Build 2073
-Fix scratching jumping to loop position when loop is further down the track
-Fix reading interlaced png files
-Fix track edits with just an image not opening as video
-Fix search action not focusing edit in multi-browser skins
geposted Sun 30 Nov 14 @ 2:16 pm
11.12.2014
Build 2087
-Fix crash on mac when scratching and pitchQuality set to 1
-Exists browser field can be sorted
-Group by genre filter folder recognizes multi-genre tags (separated by ;)
-Fix changing trigger mode from unmute
-Fix Slicer muting sound on first activation with on/off button
-Aiff tag reading
-Automix cut mode now uses 0.5 second fade like v7
-Fix midi clock output setting not saved correctly
-Don't start a second download when loading a CU track that is caching to a deck
-Caching a track that is already downloading doesn't block video
-Improvement for reading multiple tracks from audio cd
-Fix unicode compatibility for zip files
-Loading sample files in deck does not re-analyze them, keeping bpm and phase from sample
-Video logo position can be changed with controller license or karaoke subscription as well
-slicer 'length' and slicer 'step' usable in queries
-possible effect list crash fix
-Slicer 'length' and slicer 'step' can be used in queries
geposted Wed 10 Dec 14 @ 11:31 pm
17.12.2014
Build 2090
-Fix drag&drop of mp3+cdg karaoke files from explorer/finder
-Aiff tag writing
-Prelisten stop on change option added to view options menu
-TouchStrip midi object added
-Fix crash when searching and corrupt utf-8 is in database
-beat_tap can now move phase by half a beat after 4 clicks
-broadcastSongInfoFormat option added
-'In Database' filter folder fix
-Actions from master plugin apply to active deck instead of master deck by default
-Fix possible Slideshow crash
-Fix beat_tap not working properly after more than 8 beats when scan engine was not initialized
geposted Tue 16 Dec 14 @ 11:23 pm
21.12.2014
Build 2094
-Updater relaunches virtualdj with user permissions instead of administrator (should fix drag&drop after update)
-Change log can now be scrolled through, instead of creating a dialog too big to fit the screen
-Fix midi touchstrip object
-Fix some midi objects not updated with refresh_controller
-Revert plugin actions working on 'master' instead of 'active' deck
-Fix aiff tag title/artist not stored when loaded through Reload tags
-Fix for midi sysex text
geposted Sun 21 Dec 14 @ 11:14 pm
RobRoyPRO InfinitySenior staffMember since 2012
04.01.2015
Build 2117
-Improve performance of browsing big folders with cdg+mp3 karaoke files
-SSE2 audio optimizations for mac
-Fix keepSortOrder no
-Fix drag&drop from one sideview list to another
-Fix headphonesfader and auto-pfl not working together
-Fix crash when manually entering a too large deck number in controller deck selection
-Fix some speedup glitch at the end of motorscratchlocktime in some cases with motorized platters
-Fix custom sort order for top filter folders
-Fix reload tags not updating title/artist when previously read from filename
-Fix jump when disabling/re-enabling timecode in relative mode
-Fix split recording for more than 100 splits
-Add Scroll option to Text plugin
-Add Font selection to Text plugin
geposted Mon 05 Jan 15 @ 3:26 am
11.01.2015
Build 2126
-variable names case insensitive
-Fix grid lines in 4 deck skin with left-right waves selected
-Fix reset sort order broken in previous build
-CU search results that arrive late are not added to current folder anymore
-Fix midi clock out speed when pitch is not at 0%
-Show login window again if log in partially failed
-Sorting by cover supported
-Fix bug with batch analyzing songs causing automix points to be placed incorrectly sometimes
-Fix .zip karaoke files showing up twice in browser on mac when zip was added to fileFormats setting
-Browser_scroll 'top' and browser_scroll 'bottom' actions added
-Midi sysex digit item added for Numark controller
-Fix deleting a sample from a samplebank in sorted list view sometimes deleting the wrong sample
-Add some extra margin when a right-aligned column is next to a left-aligned column in browser
geposted Sun 11 Jan 15 @ 4:22 pm
26.01.2015
Build 2135
-set_firstbeat stored in database
-fix prelisten stop on change
-numark nv browser actions
-update cover flag when reading cover from tag
-Fix selected sideview forgotten after automatic update
-Fix script variables sometimes forgotten after automatic update
-Write id3 tag to wav files
-Read/write cover from id3 tag in wav files
-Fix lead in time on serato side b
-ASIO 64-bit fix
-Improved video de-interlacing
-Fix selected plugins forgotten on automatic update
-Support for older capture (directshow) capture devices
-Fix possible analyze crash
-"custom_button 1 5" syntax to select a specific variation of a custom button from scripts
-Fix rhythm wave cut off at end in some cases
-Fix cloud folder listing items double when drag&drop
-Prefer nameless comments in id3 tags
-Crossfader_hamster also applies to video
-Fix green lines at right side of some older videos
-mute action added
geposted Sun 25 Jan 15 @ 11:26 pm
28.01.2015
Build 2136
-Fix regression causing crash reading some id3 comment tags
-Added param_contains action
-param_multiply can now take an action as parameter
-Some updates to default skin (high-dpi text improvement, eq_kill display)
geposted Wed 28 Jan 15 @ 7:14 am
29.01.2015
Build 2139
-Fix regression crash from b2136
-Fix ghost slider problem with master controls
-Fix 'days left' license text for some languages
-Security window always on top
-Fix Sonique not working
geposted Fri 30 Jan 15 @ 4:01 am
04.02.2015
Build 2144
-Fix Netsearch video
-Fix crash trying to disable audio only visualisation from plugin interface
-Fix potential crash decoding videos
-Other and AutoStart plugins now loaded if user logs in after startup
-Only allow one load point to be set in POI editor
-param_contains fixed
-bug with some param_multipliers being executed twice fixed
-right-click on sideview shortcuts to remove a specific shortcut
-fix slicer multiple button presses
-fix some mp4 tag writing/reading bugs
geposted Wed 04 Feb 15 @ 6:10 am
08.02.2015
Build 2151
-Fix regression crash on reading tags from some mp4 files
-visibility used for drop zones
-fix cue marker colors in scratch waves
-vertical scratch wave shows cue markers
-Fix ignore controller not remembered for generic midi devices
-visibility working for scratch skin object
-Fix some problems when using slicer actions with Slicer not selected in a slot
-defaultmapper parameter added to controller definition
-karaoke_add and edit_singer actions added
geposted Mon 09 Feb 15 @ 1:10 am
17.02.2015
Build b2156
-fix %Pcamelot to change as pitch changes
-Export option for playlists added to copy files all the files in the playlist
-Sampler output deck stored in config
-Sampler option added to apply deck effects to sampler output
-Slip disabled on loading new track
-Scratch wave default cue marker color made more clear
-Fix touch-screen difficulty to select multiple files using ctrl or shift
-Fix sidelist/automix getting cleared when updating
-Fix midi reconnection issue that could cause controller leds to stop working
-Year now stored when saving mp4 tags
-fix shatter transition block size setting whilst not selected
-fix skin <window> element opening behind main VDJ interface on Windows
-improve support for older capture cards in camera plugin
-Fix sampler sound issue when Apply Deck Effects is active
geposted Tue 17 Feb 15 @ 11:32 pm
18.02.2015
Build 2157
-Fix song getting removed twice in Automix when remove played is active
-Fix effects not applied correctly when sampler apply deck effects active
-Fix metronome staying active in prelisten after closing bpm editor
geposted Wed 18 Feb 15 @ 11:14 pm
22.02.2015
Build 2158
-Fix regression crash with effects on samples
-Resize and move grab zones allow for visibility
-Small sampler performance improvement
-Fix automix fade point calculation for samplerate other than 44100Hz
geposted Sun 22 Feb 15 @ 10:56 am
26.02.2015
Build 2162
-browsed_file_color action to get or set the color of the track selected in the browser
-Automix list scrolls when current song is not visible in list
-Fix seeking in some videos that can only decode from start
-Added support for mask to skin cover
-resize text using param_cast 'text' x
-set action returns value so it can be used on custom slider
-sideview_title action added
-fix audio only visualisation being unloaded when trying to deactivate it
-fix screen blackout when using some combination of video effects together
geposted Thu 26 Feb 15 @ 7:01 am
09.03.2015
Build 2171
-Slicer 'hold' mode fix
-Fix for using multiple video effects on master with certain effect combinations
-fix regression bug caused by skin cover mask
-add 'mov' file support to slideshow plugin
-Fix edit_singer locking up video and skin while entering name
-Bitrate for vbr mp3's corrected during batch analyze
-New setting 'hotcueMode' with options for play and stutter when playback stopped
-Change hot_cue stutter mode to use stutterCue
-Fix param_multiply not working in some cases
-Fix regression bug with get_browsed_song
-Relocate function automatically reloads song on deck
-param_cast option added to format numbers with a specific number of digits
-touchwheel backspin/forwardspin not triggered at very low speeds
-browser_enter fix for moving to the next subfolder of an empty folder
-browser_options menu improved for touch screens
-fix sampler actions when specifying sample by name
geposted Mon 09 Mar 15 @ 12:26 am
10.03.2015
Build 2174
-Fix crash on mac closing video window with keyboard shortcut when video window has focus
-Fix deleting files from playlist when playlist is not in original sort order
-Forward spin/backspin trigger speed increased to +-40%
-Fix regression causing loading to fail/waveforms to disappear when cloning song
-new actions repeat_start, repeat_start_instant, repeat_stop
geposted Wed 11 Mar 15 @ 12:22 am
15.03.2015
Build 2177
-get_browsed_song "already played" can be used in queries
-reloop_exit returns true if there is a loop to be relooped
-Fix reading serato crates where parent crate doesn't have content
-fix sampler bug when using sample actions with samples identified by name
-allow relocate on multiple files
geposted Mon 16 Mar 15 @ 12:29 am
18.03.2015
Build 2179
-playlist_add also works for adding files selected in sidelist to playlist
-fix focus during automix not changing just by adding files
-Fix log in window popping up twice on very first start
-More serato crate fixes
-Gemini controller browser support
-Virtual Folder fix when dragging new files from explorer
-Database copy file fix
geposted Thu 19 Mar 15 @ 12:11 am
63%
