Forum: German Forum
Topic: Übersicht der aktuellen bzw. laufenden Builds und Fixes der Version 8 - Page: 7
Version 8.1 - Build xxxx
Anbei das Changelog für Version 8.1.
BUILD 2550
-Fix empty picture sometimes when video is loaded but busy seeking
-Fix empty picture sometimes after seeking video back to beginning
-Allow RPM to be set to '4 beats' so that one rotation takes exactly 4 beats
-Prevent song from stopping when loop is set past the end of the song
-Saved loop commands with no parameter now act on the first saved loop slot
-Can no longer save a loop with ID 0
-Fix vdj edit not loading completely
-Some extra checks to prevent some rare crashes
-Fix regression causing HID encoder on cdj's to stop working correctly
-Fix windows xp compatibility
-Shazam folder first seen date correctly set
-Copy length/bpm when match is found in local database for shazam
-Remove remix brackets on search to find local results when remix is in remix field
-Import facebook cookies before loading shazam login page, otherwise login to facebook has to be clicked twice
-Ensure shazam login browser window fits on screen
-Fix file deletion on mac os x 10.7
BUILD 2559
-Allow shazam folder to be re-ordered
-Loop position remains quantized when automatically moved whilst quantize_loop and loopAutoMove are both enabled
-Fix some rare crashes when refreshing the effect list
-Fix crash when dragging a delimiter from cover flow
-Fix video editor crash
-Fix some WASAPI driver close crashes
-Fix memory leak when aborting song load of a non-analyzed song
-Fix config window saying 'not logged in' when user was logged in but had no user name (google login)
-Fix sound setup showing warning triangle when user has Plus license and external mixer output, even though license supports it
-Fix shazam folder endless download loop when results are empty
-Small performance improvement querying plugin state
-Fix possible ASIO crash when ASIO samplerate is different from internal samplerate
-Fix core audio crash when core audio samplerate is different from internal samplerate
-Fix crash using controller to switch through browser lists
BUILD 2566
-Remember plugin variation/type when refreshing effect list
-Fix shazam login blocking for 2 seconds while waiting for other process
-Add support for jog wheel enable bit for HID controllers (for Pioneer CDJ's)
-Minor performance improvement in database loading
-Fix skin button getting stuck in mouse down state if it closes an effect interface
-Add right-click option to add/remove network drive from database ignore list
-Small effect_active fix
-send remix info on broadcast
-new text formats %titleremix and %artisttitleremix
BUILD 2569
- changed text for shazam login by email
- show first message for GeniusDJ folder
- On/off for HID bar
- Fix small potential crash in timecode page
- prevent shazam login window from popping up when scrolling folders from a controller
BUILD 2575
-Fix various messageboxes stuck behind config window on Mac
-Fix loop_select on encoders when moving very fast (+2/-2 as parameter)
-Fix factory default mapping not selectable
-Fix some possible deadlock issues when song is bigger than expected
-Fix Netsearch Audio
-Fix Netsearch showing chinese results for non-chinese users in netsearch folder
-Shift all cues excludes beatgrid
-New CloudList web-based interface
BUILD 2577
-Fixed reimport of v7 database
-Fix internal skin preview image not showing in config
-Xiami artist filled in more accurately
BUILD 2578
- fix reimport of old v7 database
- reimport only if v8 database more than one week older than v7
20.11.2015
V8.1 - Build 2582
-Fix slicer length not restored on restart
-Fix systray icon not removed on exit on windows 10
-Add 'Content Unlimited' text above content unlimited search results
-Fix issue with random video transition getting stuck on Droplets transition
-Add 'Restore' option for internal plugins moved to Ignore folder
-browser_sort action updates second order sort (same as clicking column headers)
-fix invert_deck for deck 4
-fix bug when adding a recursive folder with filter folder inside to sideview
-fixed deep recursion bug
-browser_scroll can be used with percentage (browser_scroll 50%)
-fix possible lockup on internet downloads
-sampler_group_volume ghost slider fix
-Genres can also be delimited by / now, not only ;
-Fix for HID encoders when overflowing
-Midi bar output accepts boolean as well (for on/off support)
-New VDJScript verb 'is_audioonlyvisualisation' which will return true if the deck currently has the audioOnlyVisualisation active
-Fix rare audio crash when soundcard samplerate is different from internal samplerate
-Slidshow can play video samples
-Sample dropped in list view starts at first row instead of second
-Serato root folder can be re-ordered
-Shazam integration
-Improved cloudlist features
v8.1 - build 2586
- fix rare potential issue when changing sampler banks very fast
- Fix rare out of memory crash when loading new tracks to a deck non-stop
- Fix multiple save issue with loop_save with no slot specified
-Remove clutter from iTunes root folder (Books, PDFs, Apps, etc...)
Build 2819
-Fix browser_sort action not reversing sort
-Can select a colour for a cue point or saved loop in the POI editor
-New VDJScript command 'cue_colour' to get/set cue point colour
-New VDJScript command 'loop_color' to get/set saved loop colour
-Fix database loading issue when drive connected after startup
-Fix deadlock on copying file that already exists in destination using drag&drop
-Fix possible sampler deadlock
-Scratchwave adjusted for zeroDb setting
-SkinSongPos improvement when shader can't be created
-WASAPI exclusive mode initialization improvement
-CSkinList mouse over performance improvement
-Fix Mac memory leak
-Fix loading of some cached cu files on mac
-Fix name on custom button for some actions
-Fix delay when quickly loading songs in a deck other than deck 1
-Fix unicode translation issue with mapper assign in configwindow
-Fix import of Serato track colours
-Serato track colour read when reloading tags
-New browser skin option 'searchbar'
-Fix bpm analysis on samplerate other than 44khz
BUILD 2821:
-Fix loading of some cached content unlimited files on mac
- Can select a colour for a cue point in the POI editor
- cue_colour command to get/set cue point colour
- Add colour selection for saved loops
- Add 'loop_color' command to get/set saved loop colour
BUILD 2828:
-Fix Podcasting
-Fix saving samples failing sometimes
-Controller mappings updated for colored cue points
BUILD 2832:
-Improve video playback for samples and slideshow
-Fix file naming when using record_cut
-Fix video when crossfader when crossfader_hamster activated
-Fix headphonesgain not applied for sandbox
-Fix mouse over visual issue in browser
BUILD 2844: (Early Access)
-EQ kill reset with resetEQOnLoad
-Improved sample video playback
-Controller updates
