Problème:
J'ai fais une grande playlist d'une bonne cinquantaine de titres, quand je veux effacer le dossier de la playlist,
il est impossible de l'effacer car on a pas accès au bouton OUI ou NON
on peut même pas réduire sur la fenêtre en pointant le pointeur de la souris en haut de la fenêtre car la flèche n'apparait pas.
problem:
I made a great playlist for a good fifty titles, when I want to delete the file from the playlist, it is impossible to delete because it has no access to the YES or NO button can not even minimize the window pointing the mouse pointer to the top of the window because the arrow does not appear.
problem:
![](/image/46340/135081/BBBBBBBBBBBBBBBB.jpg)
geposted Tue 13 May 14 @ 11:22 am
You are getting this message because it is the open Playlist in your browser and Windows thinks it is being used.
Move to a different playlist and then try again.
geposted Tue 13 May 14 @ 11:32 am
