I can't seem to find the option for this. Is their a way to change the highlight color of the tracks in the browser window back to the familiar green color instead of the light grey?
DJ James
DJ James
geposted Tue 13 May 14 @ 2:11 pm
I wish we could do that green or red would be better for me..
geposted Tue 13 May 14 @ 2:23 pm
just open the skin xml and you can customize all those colors to own liking, if one prefer red or green.. or something else
/////// BROWSER ///////
<browser>
<size width="1897" height="508"/>
<pos x="12" y="560"/>
-- for list view --
<lists background="32,32,32" stripes="42,42,42" text="255,255,255" selected="85,85,85" selectedtext="255,255,255" over="37,37,37" overstripes="47,47,47" overtext="255,255,255" focus="122,122,122" focustext="255,255,255" automix="64,128,196" scan="255,64,64" download="255,64,64" livefeedback="255,196,196" button="61,61,61" buttonactive="131,131,131" insert="255,0,0" />
-- for grid view --
<grids background="42,42,42" over="47,47,47" selected="85,85,85" text="255,255,255" label="127,127,127" focus="122,122,122" overtext="255,255,255" selectedtext="255,255,255" focustext="255,255,255" stripes="32,32,32" overstripes="33,33,33" selectedstripes="34,36,35" focusstripes="36,41,38" />
</browser>
<browser>
-- for list view --
-- for grid view --
</browser>
geposted Tue 13 May 14 @ 2:26 pm
Which part changes the highlight color, and what number is equivalent to "VDJ 7 green"?
geposted Tue 13 May 14 @ 2:29 pm
the stripes entries, in the above..
uses rgb colors
can just choose one from here :
http://www.rapidtables.com/web/color/RGB_Color.htm
uses rgb colors
geposted Tue 13 May 14 @ 2:31 pm
The default 2 deck skin XML only has the following:
<browser>
</browser>
No stripes code.
<browser>
</browser>
No stripes code.
geposted Tue 13 May 14 @ 2:41 pm
add those ;)
geposted Tue 13 May 14 @ 3:05 pm
Lots of options..... ;-) You can also use Hex code colors also.
<browser>
<pos x="7" y="569" width="1907" height="504"/>
<colors background="transparent">
<toolbars background="#212121" text="#FFFFFF" iconbackground="#000000" border="#999999" />
<lists background="#2E2E2E" stripes="#000000" over="#B3B3B3" overstripes="#B3B3B3" selected="#570000" focus="#570000" text="#999999" overtext="#000000" selectedtext="#999999" focustext="#999999" automix="#999999" livefeedback="#999999" download="#999999" scan="#999999" button="#212121" buttonover="#2E2E2E" buttonselected="#2E2E2E" buttonactive="#2E2E2E" insert="#2E2E2E" />
<grids background="#212121" over="#B3B3B3" selected="#570000" focus="#2b2b2b" text="#999999" overtext="#000000" selectedtext="#999999" focustext="#999999" stripes="#1A1A1A" overstripes="#B3B3B3" selectedstripes="#1A1A1A" focusstripes="#2b2b2b" label="#5E5E5E" />
<columns background="#212121" text="#FFFFFF" />
<scrollbars background="#2b2b2b" button="#999999" />
<info background="#0F0F0F" stripes="#000000" text="#FFFFFF" label="#5e5e5e" artist="#999999" title="#999999" />
<search background="#000000" border="#999999" selected="#333333" text="#999999" cursor="#999999" />
<prelisten background="#0F0F0F" border="#999999" selected="#999999" cursor="#2E2E2E" button="#ffffff" buttonbackground="#999999" buttonselected="#999999" />
</colors>
<fontsearch size="16"/>
<font size="16" />
<fontheader size="16" />
<fontgridtitle size="16" />
</browser>
<browser>
</colors>
<font size="16" />
</browser>
geposted Tue 13 May 14 @ 3:06 pm
Quote :
add those
Between where?
In your above example you've got no closing </browser> tag and no opening <colors> tag.
geposted Tue 13 May 14 @ 3:08 pm
dj-in-norway wrote :
the stripes entries
Just tried that, now every other line is green!
It needs to be just the highlight bar.
geposted Tue 13 May 14 @ 3:14 pm
You need to change selected then
geposted Tue 13 May 14 @ 3:17 pm
sorry fixed that now in the example ;) was a bit quick copy paste
geposted Tue 13 May 14 @ 3:23 pm
Nightmare!
On your (Dan) new full screen browser skin, the highlighted track is a dark red-ish shade.
If I switch to full screen then back again, I can get it to be green - but if I touch it or highlight another track, it reverts back to the original color.
So WHICH "selected" do I need to change? One? All?
geposted Tue 13 May 14 @ 3:35 pm
-- for list view --
geposted Tue 13 May 14 @ 3:40 pm
OK thanks. I'll give that a go later.
Would be nice if we could just pick our color choices from a menu within the VDJ config, rather than getting our hands dirty in the XML.
geposted Tue 13 May 14 @ 3:47 pm
