hot cues and beats in files from VDJ7 in VDJ8 (MAC) are not in the same place. Probably VDJ8 re-analyzes each loaded file and, BMP and shift hot cues.
The problem is that hot cues are not synchronized with new beats (looks like are moved left to the beats). Do you have similar problem?
geposted Tue 13 May 14 @ 6:43 pm
The beat grid markers no align the left hand side to bead. Rather than centering to the beat.
So they will appear off at first, but once you get used to it should be fine.
geposted Tue 13 May 14 @ 6:45 pm
This is a bug from v7 cue points. Nothing to do with the way v8 puts the grid markers. The cue points from v7 are off. We are waiting for a fix or a way to remove all of the old cue points and start over.
geposted Tue 13 May 14 @ 8:10 pm
