Am I missing something simple here ? on VDJ8 if I have a track in deck 1 with a pitch of say 90 and then I put another track in Deck 2 with a Pitch of 120 it automatically changes it to 90
Anyone know what is causing this ?
Thanks
Thanks
geposted Thu 12 Jun 14 @ 12:50 pm
I think you mean BPM, not pitch!
You need to disable autoBPMMatch in config.
geposted Thu 12 Jun 14 @ 12:54 pm
lol I can't believe I said pitch instead of BPM !! time for a rest I think !
Thanks Groovin
Thanks Groovin
geposted Thu 12 Jun 14 @ 12:56 pm
Sounds like you have the 'autoBPMMatch' option set to 'always'.
If you set it to 'smart' (default) it will limit to +-10% pitch difference (or your set pitch range, whichever is lower), when you set it to 'off' it will not match automatically at all.
geposted Fri 13 Jun 14 @ 8:41 am
I'm having a problem with my pitch bend it keeps jump and changing on its on! Please help
geposted Tue 23 Sep 14 @ 4:59 pm
please check if smartplay and/ or autoBPMMatch is set active
geposted Wed 24 Sep 14 @ 1:16 am
Hi there does anybody know how to lock 10 % pitch to stay at 10 and not going over 10 i just wanna mix song witch are compatible with 10% of pitch maximum 10% of pitch, in virtual dj 7 that was straight forward you change to 10% and it stays 10 at 10%
geposted Fri 24 Oct 14 @ 4:44 am
I just find it thanks to my self hahaha it's in options - auto pitch range i have put it no and that 's it
if anybody need this there you go !
geposted Fri 24 Oct 14 @ 4:52 am
