There are no trial keys. Download the official version then you can try it fully featured for 10 minutes. If you want to try again then just restart the software.
geposted Wed 08 Feb 17 @ 2:06 pm
My VDJ 8 doesn't support VissualEssential, why?
geposted Tue 14 Mar 17 @ 7:56 am
I have selected to add a JPG file logo, but it does not display, instead the VDJ8 logo Displays. If I select a different photo, it works fine. I have used this exact file in the past, with no problem, but now the file does not show on either the Karaoke song, or on the karaoke up next list.
Please advise. Thank you.
geposted Sun 10 Dec 17 @ 9:30 pm
SuperAceMan wrote :
Go into Settings > Options and change videoLogo to 'no' from 'yes'
Thank you!
geposted Thu 14 Dec 17 @ 2:57 pm
i have tried to remove the logo in the video buh its says that sorry you can remove it you must have alicense now how can i get alicense of virtual pro 8?
geposted Tue 30 Jan 18 @ 7:07 am
You buy it right here:
You can get it either for a specific controller (home plus), for a month at the time (pro subscription) or full eternal license (pro infinity license)
geposted Tue 30 Jan 18 @ 8:49 am
Home Plus (per controller) license doesnt remove VirtualDJ logo from Video Output. This requires a Pro License (Infinity or Subscription)
geposted Tue 30 Jan 18 @ 10:43 am
I try to change the Logo (VDJ 8.2 Pro infinit) but it won't work.
Shutting off is no Problem, but even if i show the path for the png it will only show the virtualDJ sign, not the new one.
I'll use ist for displaying the QR-Code to "ask.the.dj"-url
How do i fix the Problem?
THX
THX
geposted Wed 07 Feb 18 @ 8:28 am
Hmm
I just tried doing what I think is exactly what you are doing, with a QR code for my "ask the dj" URL, and it works for me
I recorded it (below). Is this what you are doing?
geposted Wed 07 Feb 18 @ 8:42 am
