Topic: Need a laptop for under £500-Any suggestions?
Recently my desktop has began to play up and it has became extremely difficult to run virtualDJ 7, I mainly create mash-ups and the like.
Any suggestions but not windows 8.
Thanks
geposted Wed 25 Jun 14 @ 5:44 am
the key for you is the processor and its speed - the higher you go the better it can handle things but the more it will cost. Personally I prefer Intel although others may not - its a choice thing ! Other considerations would be RAM - the more the better
I have used many different laptop brands Sony & HP for me seem stable with HP being the most cost effective. With a budget of <£500 you can get a pretty decent one new for that.
You can still get Win7 laptops on the net but not in shops like PC World ect but you can always downgrade the OS
Thanks, that was very useful
still more to consider is the graphic card..should be a dedicated graphics,not intergraded.and how much ram for graphics...
Installing the ddj-sr to laptop..
I can't seem to get the pioneer ddj-sr to work with my laptop. downloaded and updated the firmware, software. The controller doesn't even show up on my screen. what or where did i go wrong?.
maybe because your not a pro user possibly ?? not 100% sure if that matters with controllers
Your best bet is trouble-shooting the pioneer website
