I did a gig lastnight major problem Vci400 windows 7 ultimate. Ok VDJ disconnected my controller 5 times have to restart the program.
geposted Sat 05 Jul 14 @ 5:53 pm
Hello, are you logged in the program?
geposted Sun 06 Jul 14 @ 5:09 am
V7 or V8??
geposted Sun 06 Jul 14 @ 6:18 am
Valid questions. I would add, did you try a second USB cable?
geposted Sun 06 Jul 14 @ 10:23 am
also it could be a faulty usb port or a damaged power supply.
Sal
Sal
geposted Sun 06 Jul 14 @ 11:37 am
Happened to me friday night it was my powered usb'
geposted Sun 06 Jul 14 @ 3:58 pm
No power adaptors required. These is the kind I used (x2) on my Mac.
They never failed me even once.
I got mine from Staples (Canada).
![](/image/95866/141108/image.jpg)
geposted Mon 07 Jul 14 @ 12:11 am
different cable for todays gig, disconnected once, restarted the program but it didnt lock back in until i turned the controller off and on then it connected....V7 never disconnect me. I dont use any type of hub..gotta 1tb drive in laptop so just lappy and controller. Always using the same port. Disconnects my M70 mixer also. Different port different cable.
geposted Mon 07 Jul 14 @ 1:14 am
Maybe try lowering the skin FPS in 8.
It's been reported that 8 uses more CPU, and that the skin FPS contributes to it - so maybe lowering FPS
would solve the disconnection issue by taking some of the stress off the system.
geposted Tue 08 Jul 14 @ 9:49 am
Are you seeing disconnects in practice?
geposted Tue 08 Jul 14 @ 12:44 pm
ok let me try this
geposted Tue 08 Jul 14 @ 2:29 pm
Got A small park jam tomorrow gonna test Traktor for about an hour, then go to VDJ8 and see if i like one over the other. will update after.
geposted Fri 25 Jul 14 @ 11:51 am
try another pc to..
geposted Fri 25 Jul 14 @ 1:17 pm
I've been running v8 for weeks with a vci-300 and haven't had any major issues
geposted Fri 25 Jul 14 @ 10:20 pm
