Why is the mix now time fixed to 3 seconds? Please can you give us the option to change the time like on auto mix!
geposted Thu 10 Jul 14 @ 9:36 am
If you are in automix try automix_skip instead of mix_now
geposted Thu 10 Jul 14 @ 10:29 am
I havent downloaded 8 yet..what is "mix now"?
geposted Thu 10 Jul 14 @ 3:53 pm
mix_now is also available in V7.
If you are in automix and do a doubleclick on one of the files in the automix list "mix_now" is executed and it is instantly fading to the next song in the automix list.
Of the Wiki page:
•mix_now : Smoothly crossfade from one side to the other, using beatsync if both songs have enough beat.
•mix_now_nosync : Smoothly crossfade from one side to the other.
Of the Wiki page:
geposted Fri 11 Jul 14 @ 4:00 am
I think tcdj1want to set the fadetime generelly not only in automix. And i also think it's where a nice feature to set the fadetime in mix_now!
geposted Mon 14 Jul 14 @ 1:08 pm
Fading time in mix now mode is constant and cannot be changed at the moment.
geposted Wed 16 Jul 14 @ 6:27 am
You can change the 'mix_now' fade time from 0-16seconds in :
Settings/Options/Auto-Cross Lenght.
geposted Sat 27 Sep 14 @ 7:11 am
How do I adjust Fading time in mix now in VDJ8
geposted Sun 28 Sep 14 @ 11:40 am
Answer is just above your post ;-)
geposted Sun 28 Sep 14 @ 12:57 pm
Mix_now is a nice feature to map as a keyboard key.
Also the lenght of this can be changed (see above).
Is it hower possible to perform also a Bass crossfade at the same time ... with the same keyboard press ?
'THAT' would be a very nice option for the beginning DJ'er !
geposted Mon 29 Sep 14 @ 4:10 am
I am using version 8, I cannot find Settings/Options/Auto-Cross Length.
geposted Mon 29 Sep 14 @ 9:21 pm
Normally it's in automix menu, fadelength, but don't work for me :-(
geposted Mon 29 Sep 14 @ 10:34 pm
FadeLenght is only affecting the fade in automix if "fade" is chosen as automix mode.
mix_now is, IIRC, not affected by the fadeLength value and is fixed to 3 or 4 seconds.
And the action for auto crossfade is "auto_crossfade" which can hold a parameter like "auto_crossfade 2000ms"
geposted Tue 30 Sep 14 @ 4:00 am
I don't have this option but thank to you, i had a way:
auto_crossfade 6000ms & mix_now
you can try also
auto_crossfade 6000ms & mix_now & pitch_reset
juan
geposted Tue 30 Sep 14 @ 5:07 am
Where do you try auto_crossfade 6000ms & mix_now and which version?
Thanks.
Thanks.
geposted Tue 30 Sep 14 @ 9:20 pm
geposted Tue 30 Sep 14 @ 9:30 pm
