i have included two images to illustrate my question
VDJ had an option as follows
"Set this plugin to run for audio only files"
how do i achieve this same thing in virtual DJ 8? the closest thing i can find does not seem to include the plugins in the drop down menu.
geposted Sun 20 Jul 14 @ 2:03 pm
As you can see Clipbank is no more an option, best bet is to get Milkdrop for V8 it gives you high quality visuals similar to Sonique but only better.
Just install Milkdrop for version V8 and then select that as your audio only preference.
geposted Sun 20 Jul 14 @ 3:40 pm
i want to use it with pangolin, essential media, as i was doing with version 7
geposted Sun 20 Jul 14 @ 6:56 pm
Move the relevant plugin from the VideoEffect folder to the Visualisations folder.
geposted Sun 20 Jul 14 @ 7:45 pm
thanks, strange way to have to do things, but it worked... :)
geposted Sun 20 Jul 14 @ 8:52 pm
This still works for me..
geposted Mon 21 Jul 14 @ 1:36 am
A plugin that creates content is a visualisation and so should be in that folder :)
geposted Mon 21 Jul 14 @ 7:03 am
How? I think a lot of people on here would like to know how you managed that!
geposted Tue 22 Jul 14 @ 11:17 am
