Rather than a controller, I'm using a Rane mp24 board. Coming out my headphone jack on my laptop, I've tried using Numark DJ io to split my decks with no success. Is there a audio interface/external sound card out there that's compatible with VD8 and windows 8.1? Thanks...
geposted Mon 21 Jul 14 @ 11:20 pm
I use an MP44 mixer with an NI Audio 10 and a Denon HC4500 using VDJ8 running 4 decks. No problems and great sound. Using W8. My second setup is the same thing but using an Allen & Heath S2R again no problems.
Hope this helps.
Hope this helps.
geposted Tue 22 Jul 14 @ 12:05 am
You had me at Rane MP 24, When I first started using a laptop to dj back in 2001 just about every club had the Rane MP 24. Back then I used a gigaport ag sound card from my laptop into the MP24 it sounded great. Today there are many sound cards you can use , I use the audio 6 which sounds great & is mostly used with dvs. I also keep a mixvibes U-mix 44 as a backup , Its small, cheap & sounds decent, plus it works with dvs. Native Instruments has a small sound card as well, the A2. Both of these can be had for about $100.00 There are many more sound cards to choose from, I'm sure everyone has a favorite. Using the laptop headphone jack will never sound as good as having a decent external sound card
geposted Tue 22 Jul 14 @ 8:13 am
Thanks guys, I'll certainly look into the options you've given, thanks again!!
geposted Tue 22 Jul 14 @ 6:05 pm
