Forum: VirtualDJ Skins
Topic: effect/transitions cog shortcut?
hi, im working on a touchscreen skin, and am wondering if i can make a shortcut to the selected effect/transition settings cog in a button??
(its difficult to select the cog with touchpanel)
geposted Tue 12 Aug 14 @ 5:43 am
effect_show_gui 'transition' for the selected Video transitions FX GUI
deck master effect_show_gui 'video' for the selected Master Video FX GUI.
geposted Wed 13 Aug 14 @ 1:12 am
and for sound effect??
geposted Wed 13 Aug 14 @ 4:53 am
ive got 3 effects per deck, how do i get effect 2 and 3 gui, djdad please?
action="deck 1 effect_show_gui 'effect'"
geposted Wed 13 Aug 14 @ 11:42 am
locodogPRO InfinityModeratorMember since 2013
3 slots? replace 'effect' with the slot number
deck 1 effect_show_gui 1
deck 1 effect_show_gui 2
deck 1 effect_show_gui 3
geposted Wed 13 Aug 14 @ 12:32 pm
thanks locodog, that worked a treat.
now in wondering whats the code to show the values of the parameters of the effects sliders please??
geposted Thu 14 Aug 14 @ 9:16 am
Have a look at the eq or filter from the default skin, I think it's just a 'get' command
geposted Thu 14 Aug 14 @ 12:08 pm
use action instead of format in the <text /> and use one of the available get_effect_slider actions
geposted Thu 14 Aug 14 @ 4:06 pm
thanks guys i found..
<text action="get effect_slider_text"/>
<text action="get effect_slider_text 2"/>
<text action="get effect_slider_text 3"/>
geposted Thu 14 Aug 14 @ 5:07 pm
Thanks for your help guys...
geposted Thu 14 Aug 14 @ 5:35 pm
Very nice.
geposted Thu 14 Aug 14 @ 8:12 pm
