Is it possible to have two different browser focus colors? I would like the browser focused track to be the same color as the deck that it it playing on (ie; there would be a red focus for deck 1, and a blue focus for deck 2). This would also be another quick way to see which deck is playing what track when searching the browser. If possible, what would be the coding?
Thanks in advance.
Thanks in advance.
geposted Tue 19 Aug 14 @ 3:25 pm
+1
geposted Thu 21 Aug 14 @ 3:53 pm
yes you can , adding a visibility for the both browsers
i.e:
<pannel id="browser" visibility ="left select" visible="yes">
with a color
<pannel id="browser" visibility ="right select" visible="no">
with a color
ps: i didn't try so maybe you must change the command
juan
i.e:
with a color
with a color
juan
geposted Thu 21 Aug 14 @ 7:55 pm
i.e:
with a color
with a color
juan
i.e:
with a color
with a color
juan
Thanks for the response Juan.
What do you mean by "with a color"? Where would I place the color code in relation to the coding that you listed?
Is the "pannel id=" code added to the existing browser code, or is the existing code modified?
Thanks in advance.
geposted Fri 22 Aug 14 @ 2:34 pm
Indeed the solution would be to have 2 panels with browsers and show one each time, depending on the criteria.
the code above would work, as only one deck can be selected. But the criteria cant be if a deck is playing, as both can. Unless of course the priority is given to one of them.
geposted Tue 26 Aug 14 @ 3:26 pm
