Hi I like to set a loop at the beginning of my songs and then bring in the first beat with a scratch. However, in version 8 if I do this it goes to the end of the loop when I try to scratch the first beat. I.E. the song stays within the loop even when going backwards. I can't figure out how to disable this. Please help.
geposted Thu 21 Aug 14 @ 11:38 am
A new function in 8, allows the loop to move backwards. Select the pull down option in the loop gui, and disable the back function.
geposted Thu 21 Aug 14 @ 9:22 pm
Nope, setting loopbackmode to no or any setting doesn't address the issue. This is not happening in v7. A possible bug maybe.
geposted Fri 22 Aug 14 @ 6:29 am
i don't think its actually a bug but bad design if they have no way of disabling it. i just wish we could have v8 sound quality in v7. so many issues with it and it is very frustrating. i hope time will sort it all out.
geposted Fri 22 Aug 14 @ 7:28 am
Start the loop earlier and use a bigger loop or don't use loop and use a hot cue.
geposted Fri 22 Aug 14 @ 9:14 am
