I have a valid subscription for music but when i download it to cache folder it keeps saying i need to connect to internet to play songs because the cache is now expired. I update and refresh daily ( log in to site ) but every time i shut pc down and open VDJ8 again it says the same problem. Anyone got a way to fix this please. You pay for a service and it wont let you play your songs......ERMM
geposted Fri 22 Aug 14 @ 10:40 am
Anyone know what i need to do to fix this. Getting a little annoyed with this software now.
geposted Sat 23 Aug 14 @ 9:17 am
ok going to have to cancel my subscription.
geposted Sun 24 Aug 14 @ 7:42 am
geposted Sun 24 Aug 14 @ 8:12 am
As a test could you please try deleting the file from within VDJ and then redownloading it and seeing if the problem persists.
geposted Sun 24 Aug 14 @ 12:21 pm
Hi I tried that still wont play the cached files when not connected to the internet :(
geposted Sun 24 Aug 14 @ 2:15 pm
I reported the same thing !!, it does not happen all the time but if I am off-line then it tells me it is expired and to refresh ??. Even if I refresh my cache it will say that its has expired if I go off-line.
Not good for a mobile DJ.
Help please.
Help please.
geposted Sun 07 Sep 14 @ 3:11 am
If you get such an error again, would it be possible to send me the vdjcache file?
geposted Sun 07 Sep 14 @ 10:56 am
I shall do but the point being !, everywhere I look they say that Version 8 does not need to be refreshed as every time you log in it does it. This appears not to be the case for me ??.
geposted Mon 08 Sep 14 @ 3:25 am
Correct, you shouldnt have to - that is why he is asking for one of the problem files ;)
geposted Mon 08 Sep 14 @ 4:10 am
still not working .................gonna have to cancel very frustrating. And its every file that will not play not just some files. Anyone had any luck how to fix this ???
geposted Mon 08 Sep 14 @ 1:28 pm
They are looking into this. Are you able to cache new files?
geposted Mon 08 Sep 14 @ 1:45 pm
Speaking only for me I can cache new files but if I go off line always the same problem (even for the new downloaded files), very ,very annoying.
geposted Mon 08 Sep 14 @ 2:29 pm
Are you guys logging out of VDJ? I never log out, and you should not have to do this either. I am not sure if this is your issue, but my cache files play fine.
geposted Mon 08 Sep 14 @ 2:39 pm
Snap !!!!
geposted Mon 08 Sep 14 @ 2:43 pm
Are you both using PCs?
geposted Mon 08 Sep 14 @ 2:46 pm
wont work if logged in or when i log out, tried both ways. Only play files when I am logged in and connected to internet. But i want to play the downloaded files at a gig when off line............never works.
What I am saying is do not log out of VDJ, not going off line. Go on line, log into VDJ and do not log out. Play your cache files. Do not log out, but disconnect from the internet. Can you play these files now?
geposted Mon 08 Sep 14 @ 2:52 pm
Nope just tried it stayed logged in, turned off internet, and get the same message as above cache expired. :(
geposted Mon 08 Sep 14 @ 3:47 pm
Could one of you upload a problem file as requested please?
None of us have been able to replicate the issue so far - perhaps there is something peculiar happening with your files :)
geposted Mon 08 Sep 14 @ 3:52 pm
