Forum: VirtualDJ Skins
Topic: Help saving skin.PNG correctly
I'm messing about with the default skin and can't seem to save it correctly. I think it is a transparency or dpi setting which needs to be changed but am a bit lost. Even just opening the original image and then saving it will screw up the skin. I'm using Corel Photo-Paint X3.
Any guidance on the correct save settings would be gratefully received!
geposted Sat 30 Aug 14 @ 8:22 am
I installed Paint.net as recommended in another thread and it worked fine, as expected :D
However, when I opened the file I edited in Corel Photo-Paint using Paint .net it showed the correct transparency. Just opening and saving a photo paint edited file using paint.net 'corrected' it and it worked as expected... very weird!!
geposted Sat 30 Aug 14 @ 9:39 am
FruitPRO InfinityMember since 2003
The ONLY pro recommended tools are GIMP and photoshop.
geposted Sat 30 Aug 14 @ 11:02 am
Paint Shop Pro works for me.
geposted Sat 30 Aug 14 @ 12:12 pm
I use Corel Photo-Paint Essential and Photo-Filtre, they work perfect
geposted Sat 30 Aug 14 @ 12:32 pm
Paint.net
Simply the best and freeware...
geposted Wed 03 Sep 14 @ 4:12 am
