Forum: VirtualDJ Skins
Topic: Which XML editor is best to use?
I'm having great 'fun' editing my skins file but it can be a right pain! I have been using notepad to edit, which has everything I need except line numbers and is difficult to see the syntax errors (until I save and try to run it!!!).
However, I really like to way Internet Explorer displays the code and can collapse the groupings. If only I could edit the lines with it....
Which editor do you recommend/find easiest/most convenient to use?
geposted Mon 01 Sep 14 @ 10:03 am
I use pspad. It's very good and free
www.pspad.com
Keith
geposted Mon 01 Sep 14 @ 10:06 am
Notepad ++
Its freeware...
greetz
locodogPRO InfinityModeratorMember since 2013
I use np++, for more or less everything text based. (line numbers, it colour codes words so errors are easier to spot, clicking the line number highlights the entire line, auto suggestions & groupings are collapsible)
http://notepad-plus-plus.org/
geposted Mon 01 Sep 14 @ 10:12 am
Excellent suggestions, I have downloaded Notepad ++. Testing it out as we speak!
geposted Mon 01 Sep 14 @ 11:02 am
Yes, Notepad++ is the way to go.
geposted Mon 01 Sep 14 @ 1:55 pm
Just what the doctor ordered! Thanks guys :-)
Hopefully have a working prototype soon - I'll try not to annoy you with too many " how do I...." questions ;-)
geposted Tue 02 Sep 14 @ 6:41 am
