Topic: Successfully setting the 1 beat
I have the tempo tap function mapped to a couple of keys and use it sometimes to double check tempos or, more commonly, correct the half time/double time misread. When Virtual DJ 8 sets the wrong beat as the first beat, or the downbeat, I use the key to set it correctly, but I don't always have success. Sometimes I have to do it repeatedly to have it set correctly, and a few times I've just had to give up.
Anyone else have this problem?
Is there a way to adjust it manually other than the tap key?
geposted Sun 14 Sep 14 @ 8:30 pm
adjust_cbg -0.01
adjust_cbg +0.01
These scripts pull the cbg slightly left or right
Or there is
set_firstbeat
which sets the down beat on a single press
geposted Sun 14 Sep 14 @ 8:48 pm
Thanks for that. Now that I'm not at a gig I can see why the tap wasn't working for me every time, I was doing it on the fly, the song was playing. Stop the song and tap, works fine.
Can't get anything happening with adjust_cbg though, mapped it to a key and doesn't seem to move the beat.
Doesn't matter though, stop and tap is good enough.
geposted Mon 15 Sep 14 @ 12:12 am
maybe you need a repeat in there like so
repeat 1ms & adjust_cbg +0.01
geposted Mon 15 Sep 14 @ 2:05 am
Thanks, I'll try that.
geposted Mon 15 Sep 14 @ 6:31 pm
