How do you merge an existing playlist with a currently created playlist in automix??
This was possible in vdj 7 but cannot be located in vdj 8
Again, how do you change the fade-in points of the next track in AUTOMIX, without necessarily edditing the individual track on "single play"?? In vdj7, you could easily drag the mix in/out points in automix, and it is automatically stored for next time.
I tried assigning my own button for merging playlist but could only find load / add songs but not "merge playlist"
geposted Fri 19 Sep 14 @ 4:17 am
Drag n drop a Playlist to the Automix window. Then select another Playlist from the folders list. Click on any file of the list in the SOngs list (middle one). CTRL+A to select all. Drag n drop to Automix. Choose SAve.
Edits need to be done with the Automix Editor.
geposted Fri 19 Sep 14 @ 4:49 pm
