Bit confused here..
I recorded 5 or 6 tracks yesterday for a mix all the tracks were 120 - 125 ish bpm's but when I put the completed recording onto a deck it states the bpm is 60.90 ??
I've re-analysed it but still the same result.
What's even stranger is that when I mix it in it to another mix which is set at 118 bpm it blends perfectly (with a bit of pitch tweeking that is !)
Anyone got any ideas on this?
geposted Sat 20 Sep 14 @ 1:24 pm
After much studying
60*2 = 120
Sometimes bpm analysis gets it wrong most often 200% or 50% wrong.
60*2 = 120
geposted Sat 20 Sep 14 @ 2:14 pm
Hi Loco
take your point but not sure if this is the case here, I've never had this happen before, I've completed the mix parts now and put them all together and the BPM is showing as Correct 121.80 for the whole mix.
I just don't understand why one segment 'shows' as 60.90 when it clearly isn't. I analysed this bit as well in a mastering program and that showed the true bpm
odd but not a major issue unless it happens again that is !!
geposted Sat 20 Sep 14 @ 4:32 pm
Dubsteppers, d&b-ers and (like myself +200bpm) breakcore-ers are pretty used to having to *2|*0.5 bpms
(so much so that I have keyboard shortcuts (set_bpm 200%) )
I'd guess that the bpm detection goes on intensity for duration, so occasionally even constant bpm mix recordings will be 50% out
geposted Sat 20 Sep 14 @ 5:11 pm
must admit I'd find it hard to tap my feet 200 times a minute !! lol
Point taken though ! thanks Loco
geposted Sat 20 Sep 14 @ 5:21 pm
