Topic: Folder Filter help
Guys, Ive honestly tried to figure this out on my own and I dont think it's possible. But before I give up, lemme ask:
Is there a VDJ filter to show me the tracks ive played the most in the past 30 days?
Thanks for your time.
geposted Mon 22 Sep 14 @ 9:56 pm
Have you looked in the playlist folder?
geposted Mon 22 Sep 14 @ 10:43 pm
top 100 nbplay and days since lastplay < 31
geposted Tue 23 Sep 14 @ 3:37 am
RobRoyPRO InfinitySenior staffMember since 2012
you can also dl the "my libary " plugin.
There you will find more examples and ideas what else can be done with these filters
pretty good plugin ;-)
greetz
rob
geposted Tue 23 Sep 14 @ 9:10 am
"my library" is a fantastic plugin, and you can delete or customize bits of it as you see fit.
geposted Tue 23 Sep 14 @ 3:33 pm
I appreciate all the help guys. But this filter shows top 100 songs played "of all time" that I have played within the past 31 days. I am trying to find the Top 100 songs played within the past 31 days only considering play count of the past 31 days, not of all time. Thx
geposted Wed 24 Sep 14 @ 3:18 pm
days since lastplay<31 songs played last month
This will get you half way there, I'm in bed right now but I'll figure it out tomorrow and post the complete code.....
geposted Wed 24 Sep 14 @ 9:53 pm
I think that is not possible, because there is no field to store playcount depending on specific days or time spans.
But anyone is free to proof me wrong. Thinking about it, that filter does make sense. Would use it myself :)
geposted Thu 25 Sep 14 @ 4:41 am
But would involve quiet a bit of data to store it, unless of course instead of the using database.xml it used the history and got a playcount from inside a date range
geposted Thu 25 Sep 14 @ 5:58 am
