Hello, I recently started using the fader start plugin in Virtual DJ 8. I currently have the full version Virtualj DJ 8 but the fader start doesn't seem to work effectively. It works fine for it's main function but the hotkey assigned to it won't disable or enable it. When I attempt to disable the fader start from options > advanced settings > faderstart > no and faderstop > no, that won't work either. Fixes?
geposted Tue 23 Sep 14 @ 9:00 am
Not sure if faderstart plugin will work properly on V8.
But there is a kind of integrated faderstart function in V8 now.
Please habe a look at settings/ ( advanced) options ramStartTime / RampStopTime
greetz
rob
greetz
rob
geposted Tue 23 Sep 14 @ 9:03 am
Small correction:
It's called "faderStart" and "faderStartStop" ;)
geposted Tue 23 Sep 14 @ 9:06 am
I don't see how that's linked to Fader star, as they're a bit different in functions. I really need help with this, it's getting kinda irritating now. It won't even turn off till I reset my whole virtual dj 8
geposted Sat 27 Sep 14 @ 4:25 am
Eu estou trabalhando com videos, e baixei o vdj 8 só que quando reduzo o volume o video gradativamente some a medida que o som reduz . Existe algum comando
que não permita que isto aconteça. Desde já agradeço
geposted Fri 23 Oct 15 @ 12:47 pm
Please post your question here, because this is an English only forum. Thank you.
geposted Fri 23 Oct 15 @ 6:28 pm
