Since the last 2 updates I have to force VDJ to shut down. I noticed that the updates ask to be installed before VDJ comes on fully. It was always after it opened up with previous builds?? I would choose yes and VDJ would close and then re-open with the update installed.
geposted Wed 24 Sep 14 @ 3:24 pm
I guess I'm the only one it happened to?? I tried another computer and it updated fine.
geposted Thu 25 Sep 14 @ 9:57 am
I removed 8 completely and reinstalled it. No difference. It won't shut down since update 1960. The latest update included with the download.
geposted Thu 25 Sep 14 @ 10:25 am
Same problem here.
geposted Thu 25 Sep 14 @ 6:15 pm
bruh im on 1910 and cant get it to update
geposted Sat 27 Jun 15 @ 10:59 am
Have you tried downloading the latest installer from the top of the web site?
geposted Sat 27 Jun 15 @ 11:20 am
I am having the same issue having to force a shutdown. It seems that it is only happening when I open/play a video. If I stick to music, it will shut down but not after the first video is opened.
geposted Tue 16 Jul 19 @ 1:41 am
