Forum: Addons
Topic: VLoop Out
geposted Fri 26 Sep 14 @ 9:45 am
A freebie thanks very much!
IBTL :-)
geposted Fri 26 Sep 14 @ 12:38 pm
How about ping pong fade, fades out and then fades back in.
Also 3/4 and 1&1/2 loops are cool don't forget about funking it up.
geposted Fri 26 Sep 14 @ 4:50 pm
AsTheDJPRO InfinityMember since 2008
What Up Dj'sss On Loop Out I can play 2 different song deck 1 and deck 2,I loop out deck 1 then clone deck 2 to 1before it's stop the loop out cause VDJ-8 crash/freeze and NO sound b4 it goes/play in deck 1..OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
geposted Tue 28 Oct 14 @ 8:42 pm
No crash here, but replied to your other post.
geposted Tue 28 Oct 14 @ 8:58 pm
Plugin updated to v1.1 to fix a crash/freeze issue.
geposted Tue 17 Feb 15 @ 2:24 pm
ChreecePRO (OEM)Member since 2014
Thank you for this great plugin!
I think there is an opportunity to make it better. The plugin after the repeats that is set to follow, stops in a high volume output and not in a complete fade out (0%). So it fades until 50% of the volume i think and that's not quite right, it sounds like the music is suddenly stopped... It would be better if it fades from 100% to 0% in the duration of the repeats...
What's your opinion?
Thank you again for your time :)
geposted Fri 13 Mar 15 @ 2:54 pm
The plugin doesn't work anymore, also have you checked my wish from the last post?
geposted Thu 19 Nov 15 @ 5:13 pm
