I'm thinking of buying one of these, does it work ok with Vers8, and win 8.1?
Or am I going to be heading into the realms of "more bugs than it's worth" and having to map things type thing?
At the moment I use a Resident dj Kontrol 3, but I like the layout of the buttons on the WeGO, not to mention the lights!
I'd be gratefull for any good advice.
geposted Thu 30 Oct 14 @ 10:28 am
I am still using the first one that came out. I love it. its integration with Virtual DJ is perfect. I use as a stand alone controller and I also use it with my four channel soundcard (Audio 8) with my DJM 800.
I also use it with my DVS set up as an effects processor, to set cue points and loops, and to trigger samples.
Its the best $245 I ever spent.
geposted Thu 30 Oct 14 @ 11:47 am
thx for the feedback
geposted Thu 30 Oct 14 @ 11:55 am
I've have a few models of turntables and the We-Go is the best portable solution I have found for ease of travel. I love how you get to trigger and modify the effects.
geposted Sat 01 Nov 14 @ 6:52 am
Thx for that, I'm gonna try both the Wego and the Ergo next week
geposted Sat 01 Nov 14 @ 7:28 am
the ergo is decent i have one and use it daily but if its around the same price as the DDJ-SR which it was when first released i would have a long look at the SR first i think you might like it better. even if its $100 more i would still consider it if u can go the extra money.
geposted Sat 01 Nov 14 @ 7:49 am
i have the wego2, love it.
geposted Sat 01 Nov 14 @ 9:57 am
Help please I have installed OS X 10.10 Virtual Dj 7 LE introduce key start to run the program and it closes and an error! Who was this and what was the solution?
geposted Fri 07 Nov 14 @ 1:28 pm
Please try a clean installation of VirtualDJ LE by following instructions from .. http://www.virtualdj.com/wiki/Mac%20Clean%20Re-install.html
geposted Sat 08 Nov 14 @ 12:55 am
