yes i looked in options & cant seen to find these options. from tyme to tyme i change my music around add,subtract etc,etc how do i clean up my music in VDJ 8
geposted Thu 30 Oct 14 @ 11:46 pm
There is no "check" for version 8. If you need to see how many files your database has, you can type a * in the Search field.
The "Clean" is done from the Browser Options menu (small dot button, right above the font size buttons of the Browser.. Database -->Remove missing files from SearchDB
The "Fix" is done automatically on launch in case a bad entry occurs for any reason. If not mistaken, a warning message will appear in that case.
geposted Fri 31 Oct 14 @ 12:17 am
thank you
geposted Fri 31 Oct 14 @ 12:26 am
