I clicked on the Icon on my desktop and no visible window opens, but my task bar shows that its running.
geposted Mon 24 Nov 14 @ 1:06 pm
Did you reboot and try again? Do you have a second monitor attached?
geposted Mon 24 Nov 14 @ 1:45 pm
im having the same issue right now
geposted Fri 05 Dec 14 @ 11:38 pm
did you ever get it fixed... I am having the same issue
geposted Fri 05 Dec 14 @ 11:39 pm
im having the same issue please help fix
geposted Fri 05 Dec 14 @ 11:40 pm
please check if you have generic drivers installed for your video card.
Sometimes the OS uses default drivers instead of the original manufactures drivers ( e.g after a update).
If generic drivers are installed V8 will not launch.
geposted Sat 06 Dec 14 @ 10:01 am
Really? That's a strange thing to do IMO.
If the OS has started up and shows the desktop, runs other software etc. then why should it be a problem for VDJ to use them?
geposted Sat 06 Dec 14 @ 1:15 pm
Try this page, sorry, wrong side of the day to be honest... http://fr.virtualdj.com/forums/167346/PC_Version_Technical_Support/Virtual_DJ_won_t_open.html
Hopefully this will get your problem sorted.
geposted Sat 06 Dec 14 @ 7:54 pm
