Hi Folks,
I'm getting back into mixing after years away from it, I'm wondering if anyone can suggest an ideal midi controller, and possibly with integrated sound card for me. I came from CDJ-1000MK3, with DJM-909 world, so the features I really want more than anything are:
1) Live / Cue mix control on the head phones
2) headphone volume control
3) TRS or XLR balanced outputs (if sound card onboard)
4) Standard high / mid / low eq control for each channel
I realize there's a huge number of devices out there, however, I was hoping to get some feedback on what others have, what they like and what they don't like.
Thanks and sorry if this question has been asked here already, I'm new to these forums.
geposted Thu 27 Nov 14 @ 9:57 pm
What's your budget?
geposted Thu 27 Nov 14 @ 11:38 pm
From what's been stated, probably quite good!
I'd suggest that coming from a Pioneer-using background, you should check out the DDJ-SX2 and DDJ-SZ.
If that's a bit too much wonga, then the DDJ-SR. Finally there's the DDJ-SB (no bal out).
geposted Fri 28 Nov 14 @ 5:00 am
I think too when you work at last with Pioneer Equipment ,than buy a Pioneer Controller,which Modell is for you very good i waiste not.
When you look for a Lower Budget Equipment,then buy a AA VMS2 or VMS4.1
this are fantastic Controllers too,have a Good Buildt -In Soundcard and all your searched features.
http://www.americandj.eu/en/vms2.html
http://www.americandj.eu/en/vms4-1.html
Iself use a AA VMS2 and have not a problem with this, since 2011,love this Controller/Analog Mixer.
Sound and Work with this is good for me too.
Its my first Midi-Controller,and iam very happy with this.
greatings,Dirk
greatings,Dirk
geposted Sat 29 Nov 14 @ 7:22 am
