Hi. Ive bought a Numark Mixtrack 2 and it came along with VirtualDJ LE. I subscribed to VirtualDJ 8 PRO, and downloaded it. Now that its downloaded it will not connect my contoller to VirtualDJ 8, and when I go on to licences, it tells me to put in my keycode? Would appreciate help.
geposted Fri 19 Dec 14 @ 11:06 am
Have you entered your forum login ID and password? For pro/infinity it uses the login and not a key ode like LE
geposted Fri 19 Dec 14 @ 12:26 pm
i have pioneer serato i purchaced ia licence for 99 dollars i used it once then it started asking for key code where do i find this keycodes?
geposted Thu 08 Jan 15 @ 7:14 pm
As above, did you login into the software with your forum login?
geposted Thu 08 Jan 15 @ 7:17 pm
Make sure you do not log out manually also ....
Usually you just have to login once ...
geposted Fri 09 Jan 15 @ 12:48 am
