looking for and to download free jingles
in the mix jingle I need it for my dance radio show
got lots of jingles downloaded but can't get that one why
thanks
Andrew.
thanks
Andrew.
geposted Sat 31 Jan 15 @ 5:52 pm
You do know that you can record your own samples in VDJ? S0 if you can find "in the mix" anywhere, you can record it yourself. A quick search turned up this. I get most of my samples from here. They are not free, but I make money so I spend it. They have the sample you want, I just can't remember which pack it was in. You could contact them, and they could tell you.
EDIT Try Mixtape Vocals, VOX Drops.
geposted Sun 01 Feb 15 @ 3:52 am
ok thanks
geposted Sun 01 Feb 15 @ 12:51 pm
