Forum: VirtualDJ Skins
Topic: Is it possible to display the value/setting of EQ knobs?
I've just been through the SDK and script verbs but can't see anything.
I know it's possible to display values for effects and filter knobs as they're turned. Can it be done for EQ?
For example to show a dB boost or cut figure, or the frequency being affected. Even just the % value would be something.
geposted Mon 23 Feb 15 @ 6:03 am
For example:
<text action="eq_high &amp; param_cast 'percentage'"/>
geposted Mon 23 Feb 15 @ 6:23 am
Thanks - that works.
No option for dB level or frequency? IWBNI we could change the assigned frequencies from the skin with either a knob or preset buttons.
geposted Mon 23 Feb 15 @ 6:33 am
You could probably use the setting action and have some pre-defined modes with specific values (probably taken from some hardware models-mixers), but currently no way to control those values with a knob or action.
Just a crazy-untested workaround. You could possibly use the setting action along with some param_bigger/smaller and define the steps.
so something like ..param_bigger 90% ? setting (define the values) : param_bigger 80% ? setting (define other values) : ...etc.
Cant be that smooth of course, but it may offer some good options
geposted Mon 23 Feb 15 @ 1:27 pm
