Is there is a way to update my browser results in Virtual DJ 8 without having to exit out and reload the program? For example, if I DJ a party and a guest wants me to play a particular song that I currently lack in my library, I download the song while I play some other songs using VDJ8. But when I go to look for the new song in my browser results in VDJ8, I can't find it unless I exit out of VDJ8 and restart the program.
I am missing something obvious? Or is there just no way to do what I am asking?
Thanks!
Thanks!
geposted Thu 26 Feb 15 @ 4:50 pm
Yes you are missing something, make your download folder a favourite, after downloading, move off the favourite and back on to it your download should be visible.
geposted Thu 26 Feb 15 @ 4:55 pm
Thanks for the reply!
I also discovered that if you right click on the iTunes root folder it gives you a reload option that will cause the new track to appear (assuming, of course, that you imported it to iTunes after downloading).
geposted Thu 26 Feb 15 @ 5:19 pm
