dear all, i need your guys suggestion, i try to record my mix from virtual dj 8 on macbook pro, but it wont work, the record sound did not shown up, it work only from outer speaker from my laptop, how to set up the record? thanks before
geposted Wed 04 Mar 15 @ 2:20 am
What is your controller and show us a picture of your audio config please.
geposted Wed 04 Mar 15 @ 3:00 am
im using numark mixtrack pro II, after i installed virtual dj 7 it goes normal for the recording tools
here i captured my audio config, you might have some suggestion, thanks before
geposted Wed 04 Mar 15 @ 11:59 pm
Right, Mixtrack pro II after that you're not making sense.
Show me a screen shot of your audio config.
I believe you have to loop back from controller to you machine to record.
geposted Thu 05 Mar 15 @ 9:36 am
