Topic: how do I find my key code/server url
I am old school so I am new to this I was wondering how to do all the things I need to do for the radio server also my key code I don't know it or how to find it
geposted Fri 27 Mar 15 @ 9:56 pm
If by "key code" you mean a serial number for Virtual DJ 8, there isn't one. It recognises you as a registered user when you log in to it.
What radio server are you wanting to use?
geposted Sat 28 Mar 15 @ 8:04 am
I just purchased the virtual dj license but it only let me use it for 10 min even tho I purchased it it kept asking for a keycode can some help me please that's my second time purchase it
geposted Sun 19 Jul 15 @ 3:09 am
Please login to the software. There are no keycodes used in Virtual DJ 8.
geposted Sun 19 Jul 15 @ 5:54 am
Noticed you tried to use the NS7 +NS7FX but you have purchased just the license to unlock the FX unit not the NS7 itself.
You will need to additionally purchase a NS7 Plus License to unlock this controller.
Please contact Support for further options.
geposted Sun 19 Jul 15 @ 7:19 pm
Hi. Im also new to all and im too stuck. I can log in via the website fine but when I try to log in via the software with the same details it says "We cannot connect to VirtualDJ servers. Please make sure you are connected to the internet" So I too can only use my controller for 10mins even though I paid for the infinity.
Can someone help me please...
Many Thanks Jason
geposted Fri 24 Jul 15 @ 6:39 am
geposted Fri 24 Jul 15 @ 8:06 am
Just purchased 2 licenses to use my numark mixdeck with virtual dj 8. ..it's asking for a keycode even after I log in.....can some please respond. ..I have a gig tommorow
geposted Sat 26 Sep 15 @ 1:06 am
When did you purchase? I see that you are still listed as a Pro Subscriber. Can you still use that version?
geposted Sat 26 Sep 15 @ 2:51 am
RobRoyPRO InfinitySenior staffMember since 2012
Please check the licence tab, after you have logged in. For you hold various licences, there should be a box displayed right below, where you can choose which licence you want to use.
geposted Sat 26 Sep 15 @ 8:22 am
epictimeControlleristMember since 2013
How can I use my virtual dj software without connecting to the internet?
Most venues I gig at have a public WiFi and the software will not let me log in.
Please help
geposted Mon 04 Jun 18 @ 6:01 pm
You shouldn't be gigging at venues. You need a Pro license for that.
geposted Mon 04 Jun 18 @ 7:23 pm
Oh erm. I didn't know I have the wrong licence.
If I get the pro licence, can I then use it without connecting to the internet?
geposted Tue 05 Jun 18 @ 5:40 am
You can use any license without internet.
Just login to the software before, when you have an internet connection
geposted Tue 05 Jun 18 @ 6:26 am
Where can I found the code
geposted Fri 29 Jun 18 @ 3:57 am
No codes, just login to the software like you did here.
geposted Fri 29 Jun 18 @ 4:05 am
Why do I only have 10 mins I purchased virtual dj le and they asking for code smh
geposted Fri 01 May 20 @ 8:42 pm
It's not possible to purchase LE versions. They come free with controllers.
You will only get the ten minute limit if:
1) You're trying to use LE or Plus version with a different controller than it came with (or your license was purchased for).
2) You've changed the config to use settings outside the parameters of your version/license.
geposted Fri 01 May 20 @ 8:49 pm
