Treated myself to 2x Ms surface pros (for dj use)
looking to set them up side by side , length ways with mixer between them, l would like to get dj prog that would allow single deck on each (like the iPad can do)
But cannot think of one (windows) that would do?
Any ideas ,recommendations for software
geposted Sun 29 Mar 15 @ 5:51 pm
I don't think an application would be able to do this, however you can kinda do it with two laptops and the Pioneer SZ controller.
geposted Mon 30 Mar 15 @ 1:18 pm
ok if you take a look at what's going on here on YouTube ,
https://www.youtube.com/watch?v=SWOKRYVw_70
replace the 2 iPad's with the 2 MS surface
looking for some software to do the same as I dj on iPad's but on 2 windows based Ms surface's
check out the video should be able to see what I want to do (picture is worth a thousand words or so they say)
geposted Thu 02 Apr 15 @ 11:06 am
There's no reason why you couldn't use VDJ on each Surface.
It's the skin that determines what's visible on screen, so you could have a skin on each Surface that shows one deck and/or a browser.
I'm not sure if there is a skin like that yet, but it's possible to do.
geposted Thu 02 Apr 15 @ 3:27 pm
See this iPad skin for example: http://www.virtualdj.com/addons/12816/iPad_Deck.html
geposted Thu 02 Apr 15 @ 5:15 pm
Found this just what I,m after, but cannot find it anywhere?
http://www.virtualdj.com/forums/153014/VirtualDJ_Skins/Where_is_iPad_deck_s_(skin)_volume_sliders____.html
geposted Sun 05 Apr 15 @ 4:28 pm
geposted Sun 05 Apr 15 @ 7:46 pm
