Hey, can i cue up 4 songs & set them to each start automatically when previous one is ending?
geposted Fri 17 Apr 15 @ 2:27 pm
There's nothing a la carte for 4 decks. Why not use automix? or 2 decks & relay_play
You could use a repeat_start (a repeating script) but it'll be a long walk for a short picnic.
geposted Fri 17 Apr 15 @ 5:57 pm
I think it depends on where you want the cue points to be, do you want each song to start from a pre set "point", or, do you want the songs to start from a point that you have manually set on the fly?
geposted Sat 18 Apr 15 @ 9:19 am
Thanks locodog and raypitman for your responses. We are still new to this & haven't figured out a lot of anything but the "basics" yet!
We would just want to start the 2nd song, 3rd song, etc from the beginning of each song after the end of the previous song.
Are you saying we can use "automix" to do that?
geposted Fri 01 May 15 @ 3:25 pm
Probably the best place to start
https://www.youtube.com/user/virtualdjofficial
geposted Fri 01 May 15 @ 4:57 pm
