sometimes if i use the sync button it will increase the pitch range in order to sync the songs.
then this throws me off when i want to mix manually as i can never get used to the sensitivity of the pitch controll on my controller. it also makes the software pitch controll useless as a visual guide. 8% was the range on my old technics i believe, and i dont really have any interest in mixing songs beyond this range at least, without intentionally deciding on it.
is there any way to lock it at a certain percentage? or get it to warn me when its being increased?
im using VDJ version 7
geposted Sat 18 Apr 15 @ 7:08 pm
Script can set the range
pitch_range 8,
As for a warning you'll have to skin something, ask on the skinning board.
This is what the warning action would be, (if range = 8 it lights up, if not it flashes)
pitch_range 8 ? on : blink 500ms
Or you could move on to V8 and you could simply use a custom button as a warning.
If I recall V7 has a option for smart sync so if the pitch is in range it syncs if it is out of range it doesn't.
pitch_range 8,
geposted Sat 18 Apr 15 @ 7:55 pm
Just set the pitch range to 8 and disable "autoPitchRange" in the settings.
geposted Mon 20 Apr 15 @ 3:37 am
where is auto pitch range? i cannot see this option
geposted Sat 09 May 15 @ 7:53 am
PachN failed to notice you were still using VDJ 7. :-)
For version 7 it's called Auto Pitch Matching (page 39 of the manual).
geposted Sat 09 May 15 @ 8:58 am
